Nikita6996
Balanced Throttle
- 91
Well what does it say?
I also took the trouble to read the article published on JSMB, it is not of recent date and I quote verbatim "the release of sales will take place in September 2020 and the launch on the market in November 2020, overall the class if 'about 4-6 months behind schedule. " Among other things, confirms the two types of door handles, and a screen behind the steering wheel of 12.3 inches..
The article is from 29th of march. It says that everything is postponed by 4-6 months. It should be the absolute benchmark, suspension struts should be connected to the 48 volt system so when the Pre-safe thinks there is an accident going to happen the car can be raised. The interior should be based on a new interior concept with 3D buttons, it is based on OLED technology and it was shown already on the w222 door panels. It should be able to order it with the Level 3 autonomous driving - on highways up to 130km/h. New lights with 1 milions small mirrors in a main headlamp, the digital light - capable of projecting warnings on the street ahead. The long wheelbase will come with a new rear wheel steering capable of until now unseen angles. The engines - R6 diesel in S350 and S400, R6 petrol - S 450 and S 500 with 48 volt ISG and 22 PS, V8 petrol with 48 volt ISG and 22 PS. There should be also a R4 petrol and two plug in hybrids - R4 and R6 with a large battery capable of more than a 100 km drive on electricity alone.Well what does it say?
I am not convinced by their article as they mentioned the following which is false.jesmb.de is usually a reputable source
That's not always the case. The more rigid the higher the frequency in which the resonance occurs. This is a very complex matter that is influenced also not only by the rigidity but also of the type of material. Harder chassis=less squeacks but harsher resonance.It goes without saying that a rigid chassis benefits NVH suppression as well as handling and ride.
Totally agree, a stiffer and more rigid chassis does not automatically ensure better NVH or improved ride and handling unless the its combined with more efficient sound deadening materials, reduced wind noise interference(improved aerodynamics) , quieter exhaust, engine and powertrain as well as spring/damper settings and tyres used etc.That's not always the case. The more rigid the higher the frequency in which the res...
wonder if they are referring to the Digital light where it shows zebra crossings/turnings on the road?@TATE unfortunately I can read some excerpts, because the reproduction of the...
"The new S-C...
No idea how anyone could like that render. I think it’s high time we assume that the car will look worse than the W222. There’s no way those bulbous, roundish headlights with a single led strip will look better than those in the current car. Maybe the taillights will look more modern but I have a hard time believing they will possess that classy, regal look. Splitting the two screen set up and putting a huge iPad with thick borders in the center console ? Not a good idea either.I do not dislike this render, but it appears certainly less majestic than the W222....
.Sorry, do any of you know what happened to Hartmut Sinkwitz? I know that in 2015 he was head of...
