If they can make it to create V6 which is close enough to I6 in characteristics - then, sorry, V6 will be used.
This quote is very telling. Looks like people should get used to a V6 M3. Anybody who thinks it won't happen are kidding themselves.
Start think about it. Just in case.
There is an V6 prototype being tested right now. Much better configuration for the twin-turbo tech. Not to mention a bit lower center of gravity - since the engine can be a bit lower.
But there is still the weight issue, and the even bigger one: running refinement issue.
Yet they are working on that. Very hard.
Still ... the new generation of I6 is also being in development. So, there are pluses & minuses on both sides.
I have a tip for the dev. team: try to put the cylinder banks as close to eachother as possible (preferably, they should try to blend them), this will eliminate what makes the V6 such a bad configuration.If they can make it to create V6 which is close enough to I6 in characteristics - then, sorry, V6 will be used.
The E250 CGI is a 1796 cc motor 4 cyl with about 204 hp and 310 nm torque.
While most of you have obvious issues with V6s, this is not something to worry about if the end result ends up better than the current solution. When M3 had inline 6, did you cry that a V8 would ruin it? Then some seem to think that NA is what the M division is all about. Others would have it at low weight, RWD, etc. Truth of it is, any philosophy (that includes the M philosophy) that is viewed as tied to a specific technology (as opposed to a specific idea or feel) is doomed to failure. What happens when battery tech advances to the point where an electric powered car with a motor at each wheel operating independently will absolutely kill any IC car in handling/performance? Should M division just stick to the same internal combustion engine, preferably NA and inline just because you say it is so? No, it should offer the best possible driving dynamics and enjoyment using any technology that is available. That should be (and I'm thinking is) the M philosophy.
Mark Bikermann, Motorsport Division said that if BMW will make a V6, he has no doubt it will be what everyone expects. Basically he said that BMW will not do something just have it......
I believe if they go that route, it will change people's perception of a V6 engine, they wouldn't risk their reputation with an inferior product.
So, the turbos does not build anything to the height?^ The turbos wouldn't be on top of it. One of the major points of the V6 is (if I understand correctly) that they will then be able to put the turbos in between the Vee form, like they did witt the 4.4 V8...
Foxfire: yes, I did sort of cry when I read that the M3 would be getting a V8. I INSTANTLY knew this would become an M3 like we will never see again, because an M3 doesn't have 8 cylinders. 6 is the magical number for M3, and that's the way it's supposed to be. M3 GTR is fine with V8, regular M3 imo isn't. Too big. Too heavy. Too much.
I'd much rather have an I4 engine than a V6 in the M3.
Power is said to range from 163bhp (122kW) and 140 lb-ft (190Nm) for a baseline model, to 241bhp (180kW) and 192 lb-ft (260Nm) for the 1.35-litre. The 1.8-litre will produce a massive 273bhp (204kW) minimum and 321bhp (239kW) tops.
1.8 litre I4 engine with 321 bhp... feeling like a pure N/A engine... that would be really nice.
