Sunny
Yes, and MB didn't make the C63 lighter beacuse they didn't want it to outperform the SLR![]()
or the M3
Why can't I average the weights? Like you said, we don't know what the options are. So what do we know? We know data points. And it only stands to reason that we compare like for like. Otherwise, why not just consider the weight of the heaviest M3 sedan against the lightest M3 coupe and be done with it? Or would you prefer we compare the lightest M3's to the heaviest C63's? After all, we don't know the options, so let's just compare random figures without any regard whatsoever to context (their relative positioning next to each other)?I'm just giving my opinion. I'm skeptical about the weight of the sedan given comparable options to a coupe. If the M3 sedan is simiarly equipped to a C63, I expect the weights to be pretty close.
edit: I also can't see how you can average the weights, cause you can't "average" the options as there is no indication of what was on the sedan.
You expect the weights to be pretty close because you believe in the official MB weight figure. That is very unrealistic, and if you look at all available data, you would realize this. (Even if it's the figure for a stripped C63, how many stripped C63's do you think will be out there on the roads?) The differences between the M3's and C63 isn't likely down to options.
The data points are arranged in such a way that you can reasonably assume a trend; that trend is that the E92's (even the very well equipped ones) are about 200kg lighter than the C63. The guesswork in options is a moot point: considering some of these E92's are very well equipped, there is not much else that increase their weight to within what MB and BMW claim.Using these "data points" to calculate the average weight are mainly pulled from guesses in options the car has, correct? I believe in manufacturer specifications because they follow a certain standard which is CONSISTENT and REGULATED. BMW states the hp for the M3 is 420 hp, do you believe them or not?
I believe it until independent testing states otherwise. In this case, independent testing (through acceleration data and dyno testing) verifies the hp rating on the M3. Independent testing does not support MB's weight figure for the C63; nor does it support completely BMW's claim for the M3 (though to a much lesser degree). I find it very hard to believe that a base C63 with driver, luggage, and fuel would weigh 100kg less than a C63 without driver and luggage; the C63 as standard is already very well equipped!
And in this independent test, MB's hp figures for the C63 and CLK63 Black Series are called into question. Do you believe the C63 in this test is making 50hp less than the CLK63?![]()
We can rationalize that such a relatively light sedan is likely not to have many options and the other data point (from Auto Zeitung) seems to support this. If it were the 1655kg M3 that were the light one, then this indicates BMW were further from the weight mark than they claim.I edited, I'm talking about the sedan here... since this test has no indication what so ever on what options are included I can't rationalize just how one would "average" the weights. You would be surprised at how much a premium audio system can add in weight. I hope you do realize that the M3s body is still constructed mainly in steel. Only the hood and suspension components are made in full aluminum.
As I stated early in my post, I'm also skeptical about the C63s performance in this test. How did they launch the C63? Did they brake and apply throttle then let it go? Who knows... This "independent" test doesn't reveal much...
Yes. If we take BMW test results completely seriously, we'd have to think the M5 laps the 'Ring in ~7:50, and while perhaps some test mule pulled off such a miracle lap time in absolutely ideal conditions, that is certainly not representative of how the car actually performs. You yourself keep saying that you want to wait for magazine tests of these cars around the 'Ring, which tells me you value independent testing, no? Wouldn't you be the least bit interested if test after test, airfield run after airfield run, an M5 (or E63 or whatever) turns out to be no faster than a standard 5-Series or E-Class?I also infer from your post that you take magazine tests more seriously than BMW test results. To each his own...
How much does a premium audio system weigh compare to a non premium audio system? 200kg?![]()
Whether it's steel or aluminum doesn't really matter for this discussion. I already know the M3 is primarily steel. The front fenders on the M3 are injection-molded plastic, and that probably helps in the weight and weight distribution as does the CF roof. Are you implying that MB have done as thorough a job at reducing weight as BMW?
The launch is only part of the question. We can completely rule that out and look at the 60-180 or 100-180 times. Do you think the C63 is really that fast with 457 PS?
I'm not sure why you are refering to the M3 coupe, but the M3 sedan has a steel roof and sunroof as optional. I never implied MB was using weight saving material on it's body however it has used weight saving material in other areas such as the engine. In addition, whatever else BMW has done on the M3 it's still heavy. Why is it so hard to believe that the M3 sedan and C63 will be similar in weight if they are speced similarly. Is it because of the image that MB has?I think some are missing the point here.
Absolutely, what we have got so far is independent testing showing that the E90 is about 25 kgs heavier than the E92.
Are you aiming at telling us that the C63 is not at heavy as the tests tell us? I agree that on paper and by manufacturer specifications the difference should not be as much as the real world tells us but that is just the way it is sometimes.
The Scuderia is designed more as a track-oriented car, so right off the bat, there is a different marketing scheme going for that car. I never said a complete stereo deletion doesn't save weight, did I? You might want to look at the carbon fiber body and engine parts, the titanium springs, the missing carpets and sound insulation, Alcantara in place of leather, Lexan rear window, and standard carbon ceramic brakes...and then consider the 100kg weight loss.Well "likely not to have many options" is pretty vague, no? What options did the other sedan have? How can you compare this number to a C63?
The premium audio(individual) system can include two amplifiers and 16 speakers in the Beemer. Plus there are other options to consider. I wonder why Ferrari decided not to include a sound system in their Scuderia.![]()
No. It's because we have multiple independent tests indicating this.Why is it so hard to believe that the M3 sedan and C63 will be similar in weight if they are speced similarly. Is it because of the image that MB has?
That's not true. BMW issues numbers for their M cars on a regular basis. Example:BMW and MB have never issued numbers for the ring considering the amount of variables involved, more importantly, they would be held accountable for it.
If they go such lengths to cut weight on the coupe, why would you assume they stop only there? The C63's is the only engine to use weight-saving measures? No. I think the fact that BMW M bothered to develop an engine for the M3 (while AMG's engine is used in 7 other models) is an indication of their focus on this model, and a commitment to its dynamics. Weight obviously plays a part here. Out of curiosity, does the C63 use an AGM battery?I'm not sure why you are refering to the M3 coupe, but the M3 sedan has a steel roof and sunroof as optional.
So how about the premium system in the C63? What is the weight?
We don't have to have the exact same options in both cars for a meaningful comparison, do we? Going by that logic, absolutely no two cars (or their weights) can be ever compared because we don't know exactly what options they have. At that point, you may as well refrain from partaking in this thread or any thread that involves more than one car being discussed.
So is your theory that MB sent fully loaded cars for press testing while BMW sent strippers?
"Gerhard Richter, vice president of BMW’s M Division, says the M3 is 3.5 seconds quicker than the M5’s 8min 10sec lap time."
Wheels - Get bent - BMW M3
Two 'Ring numbers issued within a single sentence. In an October 2000 issue of Evo, a BMW M engineer claimed the E46 M3 lapped in 8:22 "in test trim with two people and test equipment." In a 2004 interview with Burkhard Göschel, when asked about the E60 M5's alleged 7:52 lap time, Göschel does nothing to dispel the number, and responds: ""That was a special treat, a piece of racing." Surely, the M5 as we know it in roadgoing production form is not that fast.
