- 19,991
- Martin
Many things count against Cayman actually needing AWD. First and foremost is packaging; with a Vee mid-engined car, it's relatively straightforward to route the front-axle driveshaft past the side of crankcase (R8 style) but with a horizontally opposed engine this is a much greater challenge. If you want mechanical AWD then you'd have to pass the driveshaft below the engine as the only recourse and in doing so you'd have to raise the engine and the car's CofG. In a car with such compact packaging as the Cayman, you have a better chance of seeing Taylor Swift in a hardcore porn movie.
There's always the electric motor at the front axle option but this would simply rob the Cayman of its vital essences: light weight, compactness, usable luggage volumes and low polar moment of inertia. Cayman is fantastic because of what it is, rather than what it ought to be, and so it should remain.
