To conclude this phase of the thread, I had the car back for a week or so and my expectations were exceeded.
The car feels confident, aggressive and drivable. I even don't mind taking it into the heavier stop and go traffic. Naturally all the positive ingredients of the 930 rawness are still intact like the steering and breaking.
I was only doing engine break-in kind of driving with the boost set to 0.6 bar. That actually feels quite sufficient for the driving conditions that I have here. But I will turn it up to 0.8 once Speedwerks has finished with the additional tuning based on the data that was logged during the 675 miles that I drove the car.
There have been several initial pulls showing somewhat varying results, presumably due to the initial tuning process going on. The best 0.8 pull that I saw was 531rwhp which is the number I was targeting, only at about 1.0-1.1 bar, so that is why my expectations were exceeded. There was another pull that was done a notch higher that produced this graph:
I must hasten to add though that by increasing boost here will not get me any higher - maybe 10 - 15 hp, but that's about it. The reason is that my throttle body starts choking at these power levels. So, even though the boost may have been 0.9 here, 1.1 or 1.2 would not have gotten me any higher. In fact I have other charts where higher boost levels were used and the hp results were about 12 hp less than in the graph above, although the torque levels went up to 550rw lb-ft.
So, a few points: only initial tuning done so far, hitting the limit probably at around 550rwhp/550rwtq, car feels great to drive, very torquey. I am extremely happy about the EFI conversion. Best thing I've done to this car so far. That is until the following:
I have purchased two 6 speed transmissions from a member of the Rennlist board. The 6 speeds are a G64/51 that is the transmission used in the 993TT cars, and a sequential 6 speed that started out its' life as a G50/80 (993GT2Evo transmission) and was later modified by a company called GT Ltd which is now a part of the Ricardo organization. Here's a couple of pictures (taken at Speedwerks) of the sequential with the GT2 axles, the sports clutch assembly (the flywheel is a lightweight single mass fw) and the shifter:
I had planned on installing the sequential at this time but changed my mind about a week ago. I will have the 993TT transmission installed and will save the 6 speed sequential for a track project later on.
I will utilize the LWFW/Sports Clutch though.
Once the final tuning has been done and the 6-speed installed I may post again for updated numbers and driving impressions. But for now, the initial numbers using the chart above and converted to crank horsepower and torque by dividing by the factor of 0.85 (15% loss) are approximately 644hp/612lb-ft (or 830Nm)
