Cayenne Porsche Cayenne Mk2 - First Drives (Autocar etc...)
The Porsche Cayenne is a series of automobiles manufactured by Porsche since 2002. It is a luxury crossover SUV, and has been described as both a full-sized and a mid-sized vehicle.
http://www.caranddriver.com/reviews/2013-porsche-cayenne-gts-first-drive
With the addition of the 2013 GTS to the Cayenne lineup, there are now six flavors of the Porsche SUV—the Cayenne V-6, the Cayenne S, the Cayenne S hybrid, the Cayenne diesel, the Cayenne GTS, and the Cayenne Turbo. Six variations of the same crossover make perfect sense from a company that offers 18 variations of the 911. Each Cayennee has its own personality, so choosing one is like trying to pick the right ice cream at Baskin-Robbins, except you don’t get a tiny plastic spoon. (Porsche dealers can offer you test drives but no minuscule flatware.) And there are more versions coming. Next up will be the Turbo S. After that, we’re hoping the Cayenne Bumpy Cake Swirl S gets the green light.
Cayenne Spotter’s Guide
Here’s a simple way to mentally categorize the new Cayenne GTS. It’s basically a Turbo without the turbochargers. If it were a 911, the Porsche guys would call it a Turbo-Look and the factory would call it the 958-X52 Natur, or something inscrutable like that.
The GTS comes with the Turbo’s front fascia, LED-accented active headlights, body-color fender extensions and side skirts, red brake calipers, black window frames, and darkened LED taillights. It’s not quite identical, though. For the Porsche Club judges who will be scrutinizing this SUV in 2063, we should mention that the biplane rear spoiler design differs from the Turbo’s, the four exhaust tips are matte black instead of stainless steel, and the badge on the hatch says GTS. Aside from the engine, perhaps the major difference between the Turbo and its stunt double is the latter’s $83,025 base price, $26,700 less than the Turbo’s. Start with a $66,825 Cayenne S and try to re-create a GTS. You’ll spend considerably more than $83,025, and you still won’t have the Turbo’s front end.
Lift the Turbo-style domed hood, and you’ll see a warmed-over version of the Cayenne S’s 4.8-liter V-8. A more aggressive intake cam and modified engine management are good for 420 hp, 20 more than in the Cayenne S, 80 fewer than in the Turbo. The torque gets a small bump to 380 lb-ft, up 11 over the S’s but well short of the Turbo’s 516.
The extra power isn’t particularly noticeable. What is noticeable is that the GTS feels more willing, more frisky, and more awake than the S. Shorter final-drive ratios in the front and rear differentials help the GTS move from a stoplight with more conviction. Quicker shifts from the eight-speed automatic transmission also help—Porsche claims a 0.2-second improvement in 0-to-60 times compared with the Cayenne S (we got a 5.5-second run out of the last S we tested). The six-speed manual from the previous Cayenne GTS is no longer offered, as, sadly, less than three percent of buyers opted for it. (Those folks deserve to be inducted into the “Save the Manuals!” hall of fame, if such a thing were to exist.) The 2013 GTS does have standard paddle shifters behind the steering wheel as well as the manual Tiptronic gate for the shifter.
To make sure you’re well aware that you’re in the presence of a special engine, Porsche has added a so-called sound symposer. Similar to what the Volkswagen GTI or BMW Z4 has been using for years, it works a lot like an ear horn and pumps engine sound into the cabin. A tube funnels the intake vibrations (noise) into a chamber in the A-pillar. Press the sport button next to the shifter, and all the barks, farts, and guttural sounds from the big V-8 will delight your children and possibly horrify your significant other.
In Europe, the GTS’s chassis is dropped by nearly an inch versus the S’s. In the States, we’ll only get a three-quarter-inch drop. (Drop it any lower, and the feds would call it a car, not a truck, which likely would lead to classification problems with the EPA.) A wider rear track is due to wheels with different offsets that put them nearly flush with the fenders. The adjustable air suspension is standard, as is PASM, Porsche’s electronically adjustable damper system. As on the Turbo, the GTS’s all-wheel-drive system has a set front-to-rear torque split of 40/60 in normal conditions. If slip is detected, all the torque can be sent to the front or to the rear. Porsche’s torque-vectoring system (PTV), which clamps individual rear brakes to help steer the Cayenne through corners, is standard. The optional active anti-roll bars (PDCC) keep the GTS eerily flat through corners.
In a vehicle estimated to weigh 5000 pounds, it’s strange not to get any sensation of body roll in something this tall. Much to our amazement, the Cayenne checks off all the basic virtues of a sports car. It’s stable under cornering pressure, there’s lots of grip, the brakes are strong, and it entertains without trying to kill. You just happen to be sitting way off the ground. The steering is heavy, but it builds slightly with cornering loads. Despite a loss in overall suspension travel, the ride is comfortable as long as the active shocks are left in the softest setting. It’s when you dial in sportier settings that you begin to significantly feel road imperfections.
Inside, the Cayenne is all about comfort. As in the Turbo, leather covers every reasonable part of the interior. For the unreasonable, Porsche will cover air-vent slats and probably even the gauge needles in cowhide. The seats are thronelike, thickly padded, and extremely supportive. Synthetic suede covers the headliner. The GTS cabin is a remarkably soft and happy place, even without any pink spoons to brighten it up. Speaking of, our unrelentingly black-on-black GTS made us think of squid-ink ice cream. That’s another preference that definitely requires a sample.
I just love seeing local South-African test material scans here, thanks Soup(y) It's a great country to live and work in + most of us live very good, maybe too good. We love our cars and I think it shows. Come and visit, come and test our hospitality, I'll show ya!
Back on topic. The GTS seems a 'bargain' for you get Turbo looks etc. just for much less money.
Steve is the man, one of the best reviewers on YouTube. Few reviewer go into such great detail. He's also a very nice guy in person. Respect.
Hi guys - does anybody have any info about when the facelift of the Cayenne is due?? More or less, when in model lifespans does Porsche apply an LCI/facelift? Mercedes is about the four year mark and BMW about 3.5 years..
Porsche
Official website: Porsche
