Yes, you can reduce lag, but the bigger problem is the non-linear throttle response. Lag is just one symptom of that problem - the one that pops it's head first. But with turbos you are not going to get a linear throttle response, because there is a no linear relationship between the throttle position and the amount of air being fed into the engine. It is like linking your pedal to throttle body with a rubber band. Yes, sure, you can do stuff to diminish the elastic effect, but you are not going to completely remove it. At least not with turbos as they commonly exist today. May be tomorrow with help from electrical motors accelerating/decelerating the turbos they can simulate a linear response.
Here are some comparison pics with the 458 Italia:
Ferrari 488 GTB Speciale digitally envisioned
More power, less weight
Cavalino Design has sent us two renders depicting a potential Ferrari 488 GTB in the hotter Speciale guise.
Ferrari introduced the 458 Speciale back in August 2013 as a more powerful and lighter derivative of the 458 Italia. Output of the naturally aspirated V8 4.5-liter engine was bumped by 35 HP (26 kW) to 605 HP (445 kW) at 9,000 rpm while torque remained the same at 540 Nm (398 lb-ft) at 6,000 rpm wrapped around in a body weighing 90 kg less (at 1,290 kg).
Last week, the 1,370 kg 488 GTB made its online debut with a twin-turbo V8 3.9-liter engine unleashing 670 HP (493 kW) and 760 Nm (560 lb-ft) so a potential 488 GTB Speciale version would pack even more, possibly hitting the 700 HP (515 kW) mark. The added oomph would be matched by a more aggressive body envisioned in the attached renders with vented hood and front fenders, more aerodynamic side skirts together with a beefier rear end enhanced by additional vents, carbon fiber spoiler lip, prominent diffuser and four exhaust tips although the 458 Speciale has only two pipes.
Since the 488 GTB hasn't even made its public debut, it's safe to say it will take a couple of years until a more potent version worthy of the Speciale suffix will be out.
Special thanks go to Cavalino for sending us the renders!
Source: cavalino-design.blogspot.fr
http://www.worldcarfans.com/115020988558/ferrari-488-gtb-speciale-digitally-envisioned
@Sunny I think it's that lame-grey color. It looks fantastic in Red.
Definitely not feeling it. They should have left 458 alone and came up with a new design.
