- 15,991
- Rolf
@Bridster thanks for sharing this info and hope you dont mind me posting the full table of specs, I am just blown away by the numbers.
The car will weigh about 985kg if the power to weight ratio is a huge 672PS per ton. This car is going to be stupidly fast, with split second throttle response.
I hope the engine and exhaust note will sound outrageous.
Engine Spec
No. cylinders: 12
Capacity: 3,994cc
V-angle: 65°
Power: 652 bhp
Aspiration: Naturally aspirated
Bore: 81.5 mm
Stroke: 63.8 mm
Compression ratio: 14:1
Max power: 663 PS @ 11,500 rpm
Power to weight ratio: 672 PS per tonne
Weight to power ratio: 150 kg per 100 PS
Max torque: 467 Nm @ 9,000 rpm
Flexibility: 71% of max torque @ 2,500 rpm
Maximum rpm: 12,100 rpm
Valve train: Gear driven double overhead camshafts
Inclined axis 4 valves per cylinder – variable valve timing on inlet / exhaust
Induction system: RAM induction airbox – 4 throttle bodies – Direct Path Induction Sound
Exhaust system: Inconel and Titanium
Lubrication system: Dry sump
Cooling system: Water-cooled – twin aluminium front radiators
Oil cooling system: Single aluminium rear radiator
Ignition system: 12 individual coils 12-volt
Starter/alternator: 48-volt gear driven integrated starter / generator
Exhaust emission control: 4 catalytic convertors with Lambda sensors and secondary air injection
Engine block: Aluminium alloy
Cylinder heads: Aluminium alloy
Connection rods: Titanium
Valves: Titanium
Total engine weight: 178 kg
Engine mounting: Semi-structural-inclined axis shear mounting (IASM)
Power density: 166 PS-per-litre
Engine Spec
No. cylinders: 12
Capacity: 3,994cc
V-angle: 65°
Power: 652 bhp
Bore: 81.5 mm
Stroke: 63.8 mm
Valves: Titanium
