- 19,739
- Martin
Lambornima, you need to view the above link provided by footie separately from its FWD application. XWD by Haldex is their form of torque vectoring and as such is packaged in a certain fashion to suit FWD-based layouts. This means that all the components for the LSC centre coupling, rear diff and torque vectoring components are located at the rear axle of the vehicle. With respect to the LP700, its AWD clearly is different from that of the FWD application even if it was merely swapped around front to rear. It's completely unlikely that the torque vectoring componentry will be located together with the LSC, as seen in XWD, seeing that the LSC is now situated on the front axle. Instead, the torque vectoring stuff is located at the rear diff as it should be and will probably be supplied by Haldex regardless.
So, to sum up, XWD (centre limited slip coupling, rear diff and torque vectoring) is all located at the rear axle for FWD applications. For the Lambo, just the front diff and LSC will be located up front with torque vectoring at the rear axle.
Though it did get me thinking whether the Zonda R does actually shift in 20ms or is it a case of each manufacturer measuring by different methods. In any case I doubt either time will improve our ability to drive it to it's potential.
