XF What Happens When your Battery Goes Dead in the XF? What a Pain
The Jaguar XF (X250) is an executive luxury sports saloon car that was manufactured and marketed by the British automobile manufacturer Jaguar Cars. Launched in Autumn 2007 as a replacement for the S-Type, the XF was designated internally as the X250. The X250 was succeeded by the X260 in 2015.
PHYBENZ
G-Class Explorer
I am sure this is the case with most new cars that now rely on electronics for everything.
The saga of our year with the Jaguar XF continues. When we last posted an update, we reviewed the growing list of problems with our Four Seasons test car, from minor glitches like a bad power socket to more major issues such as a bad steering pump and a failed rear differential.
Since then, the XF has had a few more miscues, the most problematic of which was a dead battery. Now, normally a dead battery isn't that big of a deal-you hook up jumper cables and you're on your way in no time. But with the XF, things never seem to be quite that simple. First of all, virtually everything in the car is electrically--rather than mechanically--controlled, from the glove box door to the trunk release to the transmission gear selector. That means that when the battery is stone dead, there's not enough juice to open the glove box so you can retrieve the owners manual. Or to pop the trunk, which is where the battery is located. Or to put the car into neutral to roll it into position for the battery to be jumped.
There are, of course, procedures to deal with such situations. Even though the XF ignition is keyless, there is a key blade that pops out of the key fob in case of an emergency. Near the door handle and rear license plate are hidden panels that can be pried open and then operated with the key so that the door and the trunk can be unlocked. And near the gear selector, about two inches below the shifter, there's a small trim piece that pops off, underneath of which is a mechanism that will cause the rotating gear knob to pop up so that the car can be put into neutral. Unfortunately, those panels are so well camouflaged that, when production editor Jennifer Misaros, who was in possession of the car when it died, looked for a hidden keyhole to open the trunk, she wasn't able to locate it. And neither could the roadside-assistance guy.
Eventually, roadside assistance was able to work around all the obstacles. Per Misaros: "I popped the hood and the roadside-assistance guy hooked up the portable jumpers to what looked like a fuse box. After twenty minutes of this, the car finally had enough juice to pop the trunk. Then the real fun started. Because the trunk is covered in carpet, there was nothing for him to use as a ground. He finally was able to rig something up so the car was getting some power. He left the jumpers hooked up for 20-30 minutes before I was able to start the car."
Never has a dead battery caused us quite so much angst, but luckily we now are aware of the XF's secret compartments. Since the battery was replaced, the Jag has been mostly trouble-free but has still had a few hiccups. The "hood open" light has flashed intermittently, and there were a couple of incidents where the fuel-filler door wouldn't open. There's a manual release in the trunk, but it's a two-man operation, as one person can't pull the release and reach the outside fuel door at the same time.(According to Jaguar, in extremely cold climates, the activator arm of the fuel-filler door can become slightly deformed so it won't open. We are informed that there will be a production change at some point.)
In more encouraging news, we've now changed the XF back to its summer tires, and the vibrations that we felt at certain speeds have completely disappeared. With the return of good weather, we're looking forward to what we hope is a trouble-free summer of driving, because despite its flaws, the engine, transmission, and overall drivability of the XF are first-class, as copy editor Rusty Blackwell reports: "As others have noted, this car is fantastic to drive. Superquick acceleration, gobs of power, clean shifts, subtle but noticeable supercharger whine. The ride is fabulous, too, typical of Jaguar. For example, my wife was driving the other night and didn't slow down for a really nasty railroad crossing in Westland. Result: Nothing. Nothing at all. We simply sailed, cloudlike, over the bumps at 45 mph."
Here's hoping we sail, cloudlike, through the second half of our year with the Jaguar XF.
(automobilemag)
(automobilemag)
Haha, that's an entertaining read. You must feel pretty bad though, unable to do anything next to the car...:D
Too bad it's unreliable, 'cause I really like the XF. Let's hope the next MY will iron out these issues.
See this is what I mean when I say that the devil is in the details. Jaguar has been working on a shoestring budget for so many years so it is silly to think their cars are engineered as throughly as the Germans. Still though they're beautiful, but Tata is still going to have to pumps huges sums of money into Jaguar (and Land Rover) to get their quality right.
Jaguar might want to consider an VW/Audi-esque approach and put their owners manual somewhere outside of the glove compartment if the release is indeed electronic and if it is true that you can't get at it with a dead battery.
That said, the driver of the long-term tester should have been more aware of the battery-jumping procedures, especially since the fail-safes seem to be so unique in the XF.
Could be worse the battery in the ML, GL and R is under the front passenger seat:t-crazy2: It is a PITA to get out.
Yeah, but you have easily accessible points under the hood to link the jumpers to. So in case of a problem, even if the battery is "hidden", the jumper are dead-easy to use to re-start the car.
And that's the difference between Jaguar and Mercedes. You don't see it, it's not written in the reviews, but it's IRL that you understand what a Merc really is.
My Dad used to say that you could park a Jag in the driveway and come back after 15 minutes and something would have gone wrong or fallen off...
He was referring to the Jags of the 80s...
So do we give this new Jag a break for being a first year production run, or are these problems widespread throughout the rest of the line?
Jaguar Land Rover
Official website: JLR
