Red Bull Red Bull Advanced Technologies RB17
Elite engineering arm of Red Bull Racing. Famed for the RB17 track-only hypercar, featuring a 15,000 RPM V10 and Adrian Newey's final F1-grade aero. Official: Red Bull Advanced Tech
Interesting that according to the article the 900 kg target is with fluids but WITHOUT fuel and driver. So curb weight will be higher. Estimated first delivery is end of 2026.
I'm surprised that there are still a small number of build slots left despite the outrageous price. The announcement of the car was 28th June 2022, so almost 2 years and 9 months ago.
Gray says he is not a fan of the supercarmaker habit of quoting meaningless “dry” weights of cars without the fluids they need to operate. So, the RB17 is weighed as an F1 car is: ready to go but without fuel or driver. The target, which the engineering team is on track to deliver, is under 900 kg, which is 1984 pounds.
The one true weight standard. Curb weigh has split into three different standards and dry weight is completely arbitrary.
When I'm the supreme leader, this is what everyone is using.
I'm having deja vu. Valkyrie team also let journalists drive the car in simulator, back in 2019. It might have even been the very same room. Although here I feel more confident that they will actually deliver.
Some stats from Jethro's two Silverstone GP sim sessions for posterity:
"T1" standard trim
  • 1:32.2 best lap
  • 3.9 g peak lateral (although earlier they said 3.7)
  • 4.4 g decel
"TX" trim (confidentials, -10 mm RH)
  • 1:26.2 best lap
  • Hangar straight speed reaching car's Vmax (370 kph?)
  • 4.5 g peak lateral
  • 5+ g decel
I also spotted these Copse speeds showed during the sim session with TX trim (which doesn't necessarily mean it was that version of RB17, as editing mishaps can happen):
  • breaking from 330 kph
  • min speed: 235 kph
Leak of the Updated RB17
Aaaand still none the wiser about the alleged fans in the diffuser.
BTW, what are these equally spaced bits in the floor? Could it be sacrificial contact points for the sealing skirts?
This is the real Red Bull RB17 hypercar and we’ll hear its 15,000rpm V10 soon
Evo.co.uk
We’ve heard it before, haven’t we? A hypercar that puts ‘Formula 1 performance’ in the hands of mere mortals (albeit very wealthy ones). The last car with this brief was the Aston Martin Valkyrie, and a staggering technical achievement though it is, a fraught development process meant it fell short of its stratospheric initial targets.
Compromise isn’t something F1 design legend and Valkyrie designer Adrian Newey finds easy to leave unresolved and so, finishing what the Valkyrie started, is the Red Bull RB17. This is the true full expression of Adrian Newey’s and Red Bull Advanced Technologies’ engineering and design vision, unrestricted by road or race regulations. The Aston Martin Valkyrie AMR Pro, Pagani Huayra R and GMA T.50S have a serious rival on their hands.
An initial concept of the car was first revealed at the Goodwood Festival of Speed in 2024 but even by this time, aero refinement and packaging were well under development. Now 18 months later, Red Bull has revealed more on what the finished article will look like, ahead of physical track testing getting underway this year. It’ll likely show up at a Grand Prix before the end of the year and we wouldn’t be surprised if it made a running appearance on the Goodwood hill in July, too.
The final design shows just how much the RB17 has evolved since that initial styling buck we first saw at its 2024 debut. What you won’t tell straight away from the images is that it’s shrunk too, although it is still comparable with a last-generation F1 car in terms of footprint. The fin above the engine cover, designed to aid high-speed stability, the double-deck front splitter and the rear wing and diffuser - now cut and multi-layered - have all been refined.
You’ll hear it before you see it, though. For at its core, bolted directly to its carbonfibre chassis, behind its two-seat cockpit is the 15,000rpm Cosworth-developed 4.5-litre V10 serving as a semi-stressed part of the structure. With the aid of a 197bhp electric motor, peak power is rated at more than 1184bhp, with drive sent to the rear through a six-speed sequential gearbox (the e-motor takes care of reverse), with new software to manage the transmission and reduce gear teeth wear. The top speed is over 217mph.
The engine could be good for a higher redline, however Red Bull deemed the extra 5000rpm that would have it matching old F1 V10s not worth the sacrifice in reliability and ease of use.
This engine has been designed to avoid the need for numerous personnel in a pit garage just to get it fired up and last 20- to 30-times longer than the Silverstone Grand Prix’s 300km race distance, or more than the record race distance for a Le Mans 24 Hours, between major services, let alone rebuilds. Scheduled maintenance will be carried out at the Red Bull Advanced Technologies HQ (major services are every 5000 miles). It can even run on 98RON pump fuel.
