Karabiner98k
Kraftkurve King
- 1,501
In the video the driver mentioned the lack of torque from the M3 in the low end. I've been saying that since the day we got the official specs on the engine.. it is too weak for that car. That engine needed some sort of a mild turbo job and it would have been close to 480hp with a very nice torque curveI mean..that 458 Italia V8 is probably very close to the limit with what you can do with a low cc, high revving NA V8
M3 has no problem with low down torque, in fact it has a very flat torque curve and due to excellent gearing it can beat many of it's rivals in low down tractability including Corvette and Viper.
Have you seen any flexibility test of the M3?? If you look at AMS and Sport Auto and even C&D test results, you will see that in high gears (5th and 6th) M3 is very strong and i'm not joking but it is more flexible than a LP640 in 6th gear from 60-100km/h!!!
The reason why that driver said something about lack of low down torque is that the new mustang GT has a very unusually close ratio box. just look at the ratios of 2nd, 3rd, 4th and, 5th:
Mustang: I)3.66 II)2.43 III)1.69 IV)1.32 V)1.00 VI)0.65
M3: I)4.06 II)2.369 III)1.58 IV)1.19 V)1.00 VI)0.87
The point is that for a car like Mustang which doesn't have a high-revving engine like the M3 and only has a 6500RPM redline, these extremely short ratios are quite unusual especially in American cars which always had extremely tall gearing.
There is not much difference in final drive ratios either:
Mustang: 3.73
M3: 3.846
Now if you compare the overall ratios of both cars, some interesting results will happen:
Overall ratios for Mustang: 2nd) 9.06 3rd) 6.30 4th) 4.92 5th) 3.73
Overall ratios for M3: 2nd) 9.11 3rd) 6.07 4th) 4.57 5th) 3.846
So, interesting isn't it?? A big engine that can't rev to high RPMs (only 6500RPM) has a shorter overall gearing than a smaller engine which can rev up to 8400RPM, and this is why that driver felt lack of torque in the M3 compared to Mustang. These gears (2nd, 3rd, 4th, 5th) are the most important gears in acceleration and laptime and are used more than any other gears when a car is driven on a track.
The general rule is that a big torquey engine should be hooked to a gearbox with tall overall gearing to compensate for it's lack of RPM and a smaller high-revving engine should be hooked to a gearbox with short overall gearing to compensate for it's relative lack of torque BUT the Mustang did the opposite: A big torquey engine and an extremely short gearing and that's why it feels more tractable than the M3. If Mustang had used a normally tall gearing (which is often used with low-revving engines), then the M3 would feel just as tractable. I personally believe that high-revving engine and close ratio transmission is the best possible solution for a supercar because it can achieve very good acceleration and low down tractability without any kind of lag in power delivery plus you will have lots of fun and excitement when you rev it up to 8000RPM or so. If you don't believe me just look at in-gear times of 458 Italia which beats even Porsche Turbo S which has much more torque at low end.
Now that would be all wrong in a sports car.
