GLB (X247) mercedes GLB 2023, hissing sound when accelerate
The Mercedes-Benz GLB (X247) is a crossover SUV produced by Mercedes-Benz. The GLB is positioned between the GLA and the larger GLC in size, however unlike these vehicles the GLB is equipped with optional third row seating due to better space distribution. Production: July 2019–2026. Model years: 2020–2026.
khoik
Autobahn Newbie
Hello,
i have GLB 200, 2023 only drive it 2200km and now i noticed when i push pedal over 2000rpm then let go it makes hissing sound, is it some leak ? or just normal turbo sound bcs its small engine ? should i put it in service ?
thank you
Sounds like the turbo to be honest? You didn't hear it before or only now notice it?
Just go and let it check, you're under full warranty I guess.
i think its turbo but should it make this noise ? noticed it like week ago,
its 1.3l engine with 120kw so maybe bcs of that ?
Yeah I suppose the engine has to work a little to move an SUV like that.... But honestly I have no idea as I have zero experience with this engine.
But the way you describe it still sounds like a normal turbo sound to me.
I believe there's a diverter valve (dump valve) fitted to the turbo housing that releases turbo pressure when you lift off the throttle. That's likely to be the source of the hiss - it's supposed to do it - but whether or not it's supposed to be that noticeable I have no idea. Pretty much every BMW I've had has developed a vacuum leak at some stage, but it's never been audible without jamming you head under the bonnet, and I'd also suggest that if there's a boost pressure problem it would throw an engine warning light fair quickly - or at least log an error code... so the obvious solution is just to take it to Mercedes garage and have them plug it in to their computer.
thank you i will just check it at mercedes to make sure, found another post from different forum so maybe it should do it
he said this
"Hello Everyone I got my Mercedes 10 months ago from Fletjer Jones Newport Beach. it's a 2023 GLB 250. So far so good except for the noise coming from the turbo whenever we accelerate the car. I noticed the second day I got the car but I thought it was normal but now it bugs me. I went to service and they told me this was turbo noise and it was normal we drove another GLB and it also had the same thing. this might be normal but it's a loud noise coming from the engine and you think there is something wrong with the engine and it is very annoying did anyone experience the same thing? I would like to hear from you."
