M5 M5 Hurricane G-Power
The BMW M5 is a high-performance variant of the BMW 5 Series marketed under the BMW M sub-brand. It is considered an iconic vehicle in the sports saloon category. The first M5 model was hand-built beginning in late 1984 on the E28 535i chassis with a modified engine from the M1 that made it the fastest production saloon at the time. M5 models have been produced for every generation of the 5 Series since 1984, with occasional gaps in production (1995 to 1998, 2023 to 2024). Official website: BMW M
H50
Turbo Tüftler
800+ HP and it broke the Brabus Rocket Speed unofficially yet this is the fastest sedan in world.
V10 Bi-Kompressor = 800+ HP and 800 Nm Torque @ 8000 rpm..
Pics from Dubai Motor Show...
Not my pics..
Is it an established, well-known, serious tuner? I don't know this, Hurricane??
A lot of turbo-kits can bring a car to 800 or 1000hp, question is will it last more than 5.000kms? Will it be more or less reliable? Is it driveable?
In one word, is this a real car or just a hp show-case that is not able to drive properly?
you be the judge:
G-POWER.DE   Start
Wow yeah looks serious!
Sponsor and official pertner of the M Drivers Club...
Did not knew G-Power. Is is really really as good as Hartge, Alpina, Hamman, AC Scnitzer and Cie? Why isn't it more famous?
Every of official BMW tuners is special in their own way.
Not famous? Maybe not to you, but i know for them for a loooong time.
Ok, my bad...
Maybe these are expensive and rare cars, more than other tuned BMW?
Anyway, I am no specialist of tuned BMW...
Well, soon we will have the Rocket vs Hurricane...Better getting out of their way!!!:angryfire :t-drive: :witch2:
luve the wheels and the steering wheel. I think it would look perfect without the 2 tone matt black finish. Would like to see a vid.
I don´t like it..it looks bit over the top for me..I like the Hartge or Alpine versions better than this one..I know,it rocks performance-wise but that´s all IMO :cool: .Sorry..I´m purist as far M´s are considered..
G-Power Hurricane BMW M5
With Audi’s RS6 pumping out 580hp thanks to its force-fed V10 engine, BMW is tipped to be testing a prototype of its M5 saloon with a pair of blowers attached, possibly for a midlife upgrade, to match its rival. Several tuning companies, however, have already proven that a turbocharged M engine can do wonders, and one such company is G-Power.
The German tuner has a twin-turbo version of the M5 with around 730hp on tap with just 0.5bar of boost pressure. That’s close to a 50% increase on the standard M5’s 507hp output, and the standard car is by no means slow.
At the recent Nardo high speed test, the Hurricane M5 reached a top speed of 322km/h but had to give up because of an electronic problem. According to developers, it can easily reach speeds of above 350km/h.
The engineers are already at work to build a version that can run 1.0bar of boost for an output above 800hp. G-Power is expected to reveal full details about the latest tuning pack at the end of the month.
Via: Evo-Cars
I am surprised that the SMG3 transmission can take all the torque.. did they modify it or is it stock?
http://jalopnik.com/339431/nothing-but-a-g+thang-g+power-reveals-730-hp-hurricane-lays-claim-to-fastest-most-powerful-street+legal-bmw
The German tuners all about powerful precision have put together one heckuva package for the BMW M5. They're calling it the Hurricane and they're claiming the $130,000+ package (or if you don't own the M5 already, just buy the package plus an M5 for a mere $352,584) makes the M5 the "fastest and most powerful street-legal BMW." It's hard to argue with those numbers when you've got a five-liter V10 engine under the hood with G-Power's own "EVO II" supercharging system capable of delivering a reported 730 HP and a top speed of 211 MPH. That's one fast M5.
Press release
G-POWER HURRICANE: 340 km/h and 730 hp: The World's Fastest and Most Powerful Street-Legal BMW
The worldís fastest and most powerful street-legal BMW is made by G-POWER. The 340-km/h G-POWER HURRICANE is based on the latest BMW M5. At the heart of the high-performance sedan is a five-liter V10 engine with G-POWER EVO II supercharging system that delivers 730 hp / 537.3 kW.
To achieve the desired increase in power output of 223 hp / 164 kW for the fast-revving engine that normally produces 507 hp / 373 kW, G-POWER, in cooperation with ASA Automotive, has developed a high-tech supercharging system. The system uses one belt-driven ASA T1-12 compressor for each cylinder bank. Contrary to conventional mechanical chargers that waste a large portion of the additional power on being driven themselves, the ASA compressor has an efficiency rate of up to 80 percent. The ASA charger is also small, which allows G-POWER to install two of them in the tight confines of the M5 engine bay. With a maximum airstream volume of up to 1,200 kg per hour per cylinder bank the compressors are designed for an even higher power output. Boost pressure is limited to 0.5 bars.
The pre-compressed charge air is cooled down in a highly efficient dual-flow water-to-air intercooler system that is mounted above the engine. This measure optimizes power yield and, in combination with a larger water-cooled oil cooler with pressure reservoir, also ensures the engineís thermal health. Specially developed mapping for engine electronics and SMG gearbox controls coordinate the perfect interaction of all new components.
The inner workings of the four-valve ten-cylinder engine are optimized for even higher engine speeds with lightweight, precision-matched high-performance forged pistons from technology partner MAHLE. The supercharged V10 engine produces its maximum power output of 730 hp / 537 kW between 7,500 and 8,200 rpm. The high efficiency rate of the two superchargers, each spinning at up to 100,000 rpm and more, results in a torque diagram that rises early and at 3,800 rpm already surpasses the production engineís peak torque of 520 Nm, delivered at 6,000 rpm. The new peak of 700 Nm is reached at 7,200 rpm.
Acceleration performance benefits accordingly. With a sprint time from rest to 100 km/h of 4.2 seconds the two-ton sedan bests its production counterpart by half a second. With approx. ten seconds to 200 km/h the advantage grows to 5.0 seconds. The 300-km/h barrier is shattered in less than 29.5 seconds. Contrary to the production car the G-POWER HURRICANE is not limited electronically to a top speed of 250 km/h. Aided by the specially cooled G-POWER anti-slip differential the engine propels the car to a top speed of 340 km/h.
The enormous performance places extreme demands on aerodynamics, tires, suspension and brakes.
The G-POWER front apron, upon request also available made from especially light carbon fiber, replaces the production part in its entirety. Its large air inlets provide optimal supply of cooling air for all radiators and front brakes. At the same time the spoiler minimizes lift on the front axle at high speeds.
The G-POWER rocker panels smooth the airflow between the wheel houses and give the M5 and longer, lower and sleeker appearance. Lift on the rear axle is reduced by a spoiler lip attached to the trunk lid and the carbon-fiber rear diffuser for the G-POWER rear apron.
Even better driving dynamics and more exclusive looks are the hallmark of the G-POWER Silverstone 21-inch light-alloy wheels that fill out the space beneath the wheel arches perfectly. The drop-center rims have brilliant-graphite coated centers while the outer rim wells and spokes are polished. They are mounted in sizes 9.5 J x 21 with size 255/30 ZR 21 tires in front and size 10.5 J x 21 wheels with size 295/25 ZR 21 tires on the rear axle. Technology partner Dunlop provides the perfect high-speed tires.
The large wheels make room for the G-POWER high-performance brake system with six-piston fixed calipers and 400 x 36 millimeter brake discs on the front axle. G-POWER also offers an upgrade package for the standard M5 brakes that consists of high-performance pads and brake fluid.
The M5 handling can be made even sportier by installing the height-adjustable G-POWER coil-over suspension RS with nine selectable settings each for bound and rebound.
For upgrading the cockpit G-POWER offers sporty components made from exposed carbon-fiber trim or an ergonomically shaped NARDO EDITION sport steering wheel covered in perforated G-POWER Kjerba-Nappa leather that is a pleasure to touch.
The G-POWER HURRICANE is available as a fully converted car starting at 240,000 Euros. Any existing M5 ñ sedan and wagon ñ can also be upgraded with the G-POWER twin-compressor system, available for 89,000 Euros. The price includes all necessary modifications to suspension, brakes and wheels. Also available are any items from the extensive G-POWER tuning accessories lineup.
Mother of all M5s :icondrool :bowdown:
G-Power M5 Hurricane -
730bhp, 700NM, 5.0 lit twin supercharged engine
0-100km/hr - 4.2 sec
Top Speed - 360km/hr
Price - 240.000 Euro (Germany)
A geman test - Enjoy :t-cheers:
BMW M
