Automobile Mag - Lamborghini Gallardo Superleggera and Porsche 911 GT3 RS: Extreme...
Ultimate Gearhead Guru
Marcus
That’s a typical sequence of mind-sets one is likely to go through when approaching two no-holds-barred supercars like the wild Porsche 911 GT3 RS and its equally exciting new soulmate, the Lamborghini Gallardo LP570-4 Superleggera. Even Walter Röhrl, the lanky superstar who can beat God around the Nürburgring’s Nordschleife, freely admits that the sharpest street-legal scalpels still stir his stomach whenever he approaches them, ignition key in hand.
Duck your head, limbo in, probe the footwell for legroom, lower yourself carefully into the Sparco tub, stretch out, exhale, and relax if you can. No, the Gallardo cockpit is not made for tall fatsos like me whose Gold’s Gym membership expired in 1972. Which is a shame, because the Superleggera epitomizes luxury in a modern, laid-back fashion - super, yes; leggera (light), less so. Almost the entire passenger cell is lined with black Alcantara, which looks and feels like suede. To reduce weight, the door panels, the transmission-tunnel cover, and the seat buckets are made of shiny carbon fiber. Other nice touches include special instrument faces, body-color accents such as contrasting stitching and piping, aluminum pedals, and a meaty steering wheel with an ever-so-slightly squared-off bottom.
Painted orange metallic, our fully loaded test car was charmingly over-the-top, what with orange weaving in the seat faces and orange brake calipers. To shed the 154 pounds required to bring the power-to-weight ratio down to 5.3 pounds per horsepower, the engineers switched the rear side windows and the backlight to distortion-prone polycarbonate. The high-gloss engine-compartment cover, the rear diffuser, the front splitter, parts of the undertray, and the extrawide rocker panels are baked from carbon fiber. Not exactly essential - but nonetheless available at extra cost - are such attention grabbers as an LED-lit engine bay; cabin and puddle lighting packages; and the stacked, nonadjustable, Countach-style rear wing. All in all, the more radical material mix helps reduce dry weight to 2954 pounds, which isn’t bad at all for a fully loaded, V-10-engined, four-wheel-drive supercoupe.
Our Porsche 911 GT3 RS test car has no rear seats, no air-conditioning, no radio, no apparent noise insulation, no central locking, not even proper inner door handles - instead it has red, pull-to-open fabric ribbons. From the outside, the Porsche looks even gaudier than its brother in arms from Emilia-Romagna, but inside, the ultimate two-wheel-drive 911 is almost as barren and minimalist as a race car. The narrow, thinly padded seats take less than a day to change the complexion of your behind to hurting-baboon red, and the car, both inside and out, is decorated with more RS 3.8 badges, stickers, and decals than the year has months.
This is definitely not a subtle Porsche. In particular, the adjustable, double-decker, carbon-fiber tail appendage with the contrasting winglets is liable to turn heads. The wingwork hates automatic car washes, but, in combination with the aggressively shaped front apron, it provides enough downforce even for courage-testing high-speed autobahn esses. Other changes that differentiate the RS from the regular GT3 include a wider front track (by 0.5 inch), a wider rear track (by 1.2 inches), a rear window and engine-compartment lid made of lighter synthetic material, a neatly integrated ram-air induction scoop, and a pair of larger-diameter tailpipes. Also contributing to the 55-pound weight savings versus the 3076-pound GT3 are a muffler made of titanium and a single-mass flywheel, as well as detail changes like the low-calorie, single-function steering wheel and a composite transmission-tunnel cover.
The tight-fitting Superleggera makes for an intense driving experience. The one-size-fits-few seats are like suction cups, and the instant throttle response launches the car forward like an ejector. The ultraquick steering feels like a high-voltage handshake, the merciless brakes threaten to inflict whiplash injuries, and the suspension holds the road like an unsprung magnetic field. With go-faster stripes and plenty of drag-cutting add-ons, the Superleggera marks the transition from boulevard racer to hard-core supercar. This Lamborghini straddles the line between punishment and reward. Its exhaust system temporarily impairs your hearing, and its ability to rocket you down the road blurs your field of vision. Phenomenal grip and traction make the mighty orange wedge stick to its flight path as if inertia, mass, and g-force were totally negligible dynamic commodities.
In character and configuration, these two supercars could hardly be further apart. Superleggera versus GT3 RS? That’s all-wheel drive vs. rear-wheel drive, aluminum spaceframe vs. predominantly steel, mid-engine vs. rear-engine, V-10 vs. flat six, 5.2 liters vs. 3.8, direct vs. port injection, automated vs. manual transmission, control-arm vs. multilink suspension, fixed vs. variable aerodynamics, about $243,000 vs. $135,050. The Lambo is the quicker car in all departments, but the 911 feels quicker - in part because it’s noisier and looks more raw.
Hugging the tail end of the Porsche’s substantial behind, the most extreme normally aspirated street-legal boxer engine ever conceived in Weissach develops 450 hp at 7900 rpm. Redlined at 8500 rpm, the 3.8-liter unit requires a steroidal 6750 rpm to whip up the maximum torque of 317 lb-ft. Pushing the Sport button frees an extra 35 lb-ft where you need it most - in the 3000-to-6000-rpm range - with an accompanying increase in exhaust sound. The power output of the RS engine is only 15 hp more than that of the GT3, and the peak twist action is unchanged, although it requires an extra 500 rpm. A final drive that’s thirteen percent shorter knocks 0.1 second off the GT3’s 4.1-second sprint to 62 mph, claims Porsche. The larger frontal area and the revised gearing also knock one notch off the top speed, although 193 mph is certainly fast enough.
Full Story: Lamborghini Gallardo Superleggera and Porsche 911 GT3 RS - Exotic Sport Coupe Comparison - Automobile Magazine
Just imagine…:
Curvy country roads…sun…dry roads - and then these killer machines…sound, and pure emotion… :bowdown:
