cawimmer430
Piston Pioneer
- 14,806
- Christian Alexander Wimmer
BMW X6
Test date 12 November 2007 Price when new TBA
What is it?
Nothing less than a whole new genre of car, according to BMW. The german car-maker refers to this, its new X6, as a Sports Activity Coupe, or SAC. Others call it a crossover 4x4. And we’re the first to drive it.
Given our brief stint behind the wheel of a validation prototype on Michelin’s test track in South Carolina this week, it is clear BMW is taking a big risk with its latest model. The radical new X6 attempts to blend the inherent sportiness of an upmarket coupe with the go-anywhere ability and toughened styling of a luxury four-wheel drive. The result is a car quite unlike anything else on the road today.
It’s difficult describing the way this car looks to those who’ve never seen it in the metal. Imagine the arched roofline of a 6-series sat on the high-sided body of an X5 and you’ll begin to get some idea of what BMW has created here. It likes to refer to the car as a coupe, but with four doors and a huge one-piece liftback that opens up to reveal an enormous boot, it’s a coupe unlike any other you’ve seen.
The production version of the X6 is little changed to the concept revealed at the Frankfurt motor show back in September. The basic styling, with its taut surfacing and heavy creases, is highly reminiscent of the X5, although BMW says each body panel is unique. As with its more practical sibling, the body is a combination of steel, aluminium and plastic. No kerbweight figure has been put forward just yet, but you can bank on it being over 2000kg in base trim.
What’s new?
Photographs tend to mask the X6’s real size; it’s actually both longer and wider than an X5. Thanks to its more acutely raked windshield and shallower side glass, though, the X6's roof is around 60mm lower.
Practicality has clearly been a secondary consideration, with entry to the rear severely restricted by the intrusion of the large rear wheel arches into the door apertures, and rear seat headroom compromised by the heavy curvature of the roof. In an odd move, BMW has also decided to equip it with just four seats – a move that’s clearly aimed at separating it from the X5, which now comes with the option of a third seat row to boost its seat count to seven in total.
Based on the same four-wheel drive underpinnings as the second-generation X5, the X6 receives new driveline components that add to its dynamic prowess. Central among them is DPC (Dynamic Performance Control) – an advanced new torque vectoring system which allows the engine’s reserves to be apportioned not only between the front and rear axles dependant upon grip, but also between the individual rear wheels, in a process that is claimed to provide more neutral handling.
The idea is to direct drive to where it can be used most effectively, in an operation not dissimilar to that of a traditional locking differential on a rear-wheel-drive car. Unlike similar systems developed by its rivals, DPC operates both under load and on the overrun, meaning the X6 continues to be stabilized even when the driver steps off the throttle mid-corner.
During understeer, it automatically directs the majority of drive to the rear wheels and loads up the outside rear wheel, providing additional turning momentum beyond that generated by the steering. During oversteer, it essentially reverses the action, sending the majority of drive to the front wheels and loading the inside rear wheel.
Other changes over the X5 include a 60mm stretch in rear track. The ride height also drops by 10mm, reducing the X6’s ground clearance to just 202mm. The lower roof also helps reduce the car’s centre of gravity by around 30mm, according to Hans Krausche, head of BMW’s chassis development.
We can’t tell you much about the engine line-up just yet. BMW would only admit that the prototypes we drove ran developments of its twin-turbocharged 3.0-litre in-line six-cylinder petrol and diesel engines. The German car-maker is tight-lipped on the actual outputs of each unit, although it does hint that power will be extended beyond the 306bhp and 286bhp seen in other BMW models.
Also planned to head into the X6, but yet to be made official, is a turbocharged version of BMW’s 4.8-litre V8 with around 410bhp. There will also be a hybrid version.
What’s it like?
For a big and heavy SUV, the X6 possesses a healthy turn of speed and is remarkably agile through tricky combinations of corners.
A new eight-speed automatic gearbox provides a wide spread of ratios that help make the most of the engine’s strong torque characteristics. For the most part, it shifts smoothly, but can prove indecisive with an odd pause between shifts when you’re really hauling along. Paddles behind the steering wheel allow you to shift manually, as does the electronic shift lever.
BMW’s not making any official performance claims just yet, but expect the twin-turbocharged 3.0-litre petrol-powered X6 to hit 60mph in under 7.0sec, on the way to an electronically limited 155mph top speed. It’s all helped by a standard brake energy regeneration system that decouples the alternator under acceleration and uses energy created under braking to recharge the battery.
Granted, we’ve only driven it on a circuit and under controlled conditions but there’s no getting away from the fact that the X6’s handling sets new, lofty standards for a car this size. Perhaps more importantly given the badge sitting up front in the middle of its kidney grille, it’s a very entertaining car from behind the steering wheel.
The effectiveness of DPC is immediately obvious; the X6 prototypes we drove were noticeably sharper in their actions than the standard X5 that was on hand for comparison purposes. By varying the degree of drive to either the left- or right-hand side rear wheels, it cornered in a more neutral fashion and with greater purchase from its big Dunlop SP Sport Max tyres. The system is seamless and fast-acting. You don’t notice it transferring the drive, but you do feel the benefit.
The new BMW boasts superb levels of body control, loads of traction and a heightened level of grip. Comparisons with the Porsche Cayenne will have to wait a few months, but we wouldn’t be surprised to see the BMW X6 shoot straight to the top of its class on dynamic prowess when it is launched early next year.
As well as providing more neutral handling, DPC also serves to cut the amount of steering input required. It was noticeably reduced during lane change manoeuvres and more challenging skid pan tests laid on by BMW. When mated with BMW’s active steering system, it provides the X6 with a highly direct steering feel. Turn-in is miraculously sharp for such a hefty lump of four-wheel drive, yet stability remains rock solid at higher speeds.
Should I buy one?
It’s too early to be sure; our drive of the X6 was way too short to indicate with any certainty just how it will perform on the road. We don’t know enough about its mechanical specification or its projected price to recommend it, either. Rest assured, though, that if you’ve placed an order on one in the hope of taking delivery of the finest-handling SUV on the market, you’re exceedingly unlikely to be disappointed.
Greg Kable
Link: BMW X6 - Road Test First Drive - Autocar.co.uk
What is it?
What’s new?
What’s it like?
Should I buy one?
Greg Kable
