Volvo Testing Power-Adding KERS Flywheel Tech
Human
You. The Road. Nothing else.
Naas
Volvo says it is hard at work developing a flywheel energy recovery system that could make a four-cylinder engine have six-cylinder like power while consuming even less fuel than before.
The Swedish automaker isn’t the first to have discussed Kinetic Energy Recovery Systems – or KERS – but it might become the first to conduct serious real-world testing thanks in part to a $1 million grant from the Swedish Energy Agency. The grant will help the automaker put a vehicle equipped with KERS on the road during the second half of this year.
Just what is KERS?
Flywheel KERS isn’t a simple subject. Fitted to the rear axle of a car – in the Volvo’s case – it grabs braking energy that causes the flywheel to rotate as fast as 60,000 rpm during extremely hard braking.
From there, it uses a transmission module to transfer power right back into the rear wheels to help propel a vehicle – all without using other significant sources of energy.
“The flywheel’s stored energy is sufficient to power the car for short periods. However, this has a major impact on fuel consumption. Our calculations indicate that the combustion engine will be able to be turned off about half the time when driving according to the official New European Driving Cycle,” Volvo Powertrain Engineering VP Derek Crabb said in a statement.
Volvo uses a start/stop system to turn off the internal combustion engine located under the vehicle’s hood as soon as the driver starts applying braking, but the engine kicks back on when the gas pedal is tapped. Once the car begins accelerating, the KERS flywheel can add as much as 80 horsepower to the powertrain. Fuel consumption is down about 20 percent in city driving, Volvo says.
The technology is most useful in urban driving, where cars are accelerated and then braked repeatedly, because energy storage ability is limited. To save weight and to increase rotational capacity, the KERS flywheel is made of carbon fiber, a material that Volvo says it wouldn’t have been able to effectively use until now.
Volvo released a video, found below, which helps illustrate the technology.
Source: Leftlanews
Volvo
Volvo Cars is a Swedish multinational manufacturer of luxury vehicles. Founded in 1927, Volvo is headquartered in Torslanda, Gothenburg, Sweden. The company has been owned by the Chinese multinational automotive company Geely since 2010. Volvo also produces electric vehicles under the Polestar brand.
Official websites: Volvo, Polestar
