M3/M4 Road and Track - M3 V-8: An Inside Look
The BMW M3 is a high-performance version of the BMW 3 Series, developed by BMW's in-house motorsport division, BMW M GmbH. M3 models have been produced for every generation of 3 Series since the E30 M3 was introduced in 1986. The BMW M4 is a high-performance version of the BMW 4 Series automobile developed by BMW's motorsport division, BMW M, that has been built since 2014. As part of the renumbering that splits the coupé and convertible variants of the 3 Series into the 4 Series, the M4 replaced those variants of the BMW M3. Official website: BMW M
The centerpiece of what makes the newest member of the M lineup so special.
Beneath the bulging "power dome" lies the engine of the new M3, code-named S65B40, and the centerpiece of what makes the newest member of the M lineup so special.
Built at BMW's foundry in Landshut outside of Munich, which also happens to produce engines for BMW's Formula 1 team, the V–8 engine has been in development for three years. This sounds like a short time, but BMW didn't have to start completely from scratch. Much is borrowed from the S85B50 V-10 found in the M5 and M6, from the pistons and connecting rods to the capacity of each cylinder. This V–8 not only produces a commendable 414 bhp at a stratospheric 8300 rpm, but — at 445 lb. — actually weighs 33 lb. less than the outgoing inline-6.
It all starts at the 18-liter airbox, which houses what looks like eight bowing velocity stacks arranged on either side of the box, facing upstream. The airbox gets its air via three intakes: one in the front fascia, one behind the grilles, and one behind the driver-side vent adjacent to the power dome (the other side is sealed off to help pressurize the engine compartment and expel heat). The air travels through a high-flow filter element directly to the composite trumpets, without encountering a mass-airflow sensor first. Calculations and adjustments for air and fuel are handled by the ECU, which accounts for air temperature, air pressure, throttle position and engine speed, among other things, to determine an optimum ratio. This in turn eliminates the need for cylindrical intake piping (needed for accurate air mass computation) and a hot-film sensor disrupting the 17 liters of air per minute the new V–8 needs at full song.
From here, air is sucked through eight individual throttle bodies, which have been placed extremely close to the intake valves to maximize throttle response. Each row of four throttle bodies is controlled via an electronic actuator, which translates inputs from the throttle-pedal potentiometer (sampled at 200 Hz), and can be fully opened in a mere 0.12 second.
The air/fuel mixture then travels into the sleeveless combustion chambers where iron-coated aluminum pistons compress it to 1/12 its original volume. The all-aluminum engine block is a two-piece bedplate design that uses more than 50 studs to rigidly attach the upper crankcase to the lower half, and precisely locates and supports the forged-steel crankshaft. Gray cast-iron inlays, in which the crankshaft bearings sit, help reduce the thermal expansion of the aluminum structure and keep operating tolerances tight as temperature rises.
BMW's double-VANOS technology allows for optimal valve timing adjustment on both intake and exhaust (58 degrees on the intake, 48 on the exhaust, at a rate of 360 degrees per second), but has been improved since implemented on the V–10 engine. It now uses the combination of a step motor coupled to a sprocket to adjust timing, instead of the high-pressure oil-driven system that directly rotated the camshaft. The benefit of this is the elimination of a supplementary oil-pressurizing system and additional plumbing, replaced with a tidier setup using normal engine oil pressure to activate the step motor.
Oil level/pressure is monitored by an electronic sensor and reported to the driver via a display in the gauge cluster. While this may seem a bit unnerving to some who will miss a car's dipstick, BMW swears its system is not only dependable, but more effective in notifying the driver immediately of an oil issue.
You won't worry about oil starvation either, as design improvements to the oil sump ensure relatively uniform oil flow across the rpm range and under extreme lateral and longitudinal g-forces. The main sump located at the rear of the engine collects oil under most conditions, while an ancillary front sump is mainly in charge of scavenging oil under braking, sending it back to the main sump for recirculation. Although dry-sump setups are common in modern high-end sports cars, BMW felt its wet-sump design was optimal for this engine. Michael Menn, engine expert and project manager for BMW M, explained that the wet-sump system not only saves weight over a dry sump, but packages better and allows for a proper-size intake to feed the oxygen-hungry V–8. BMW engineers tested the system under sustained lateral and longitudinal forces of 1.4g's for about 13–15 sec. at a time (that should cover about 110 percent of worldwide racetrack corners or canyon roads).
Expelling the exhaust gases from either bank are equal-length 4-into-1 headers that keep exhaust flows separate on each side while passing through two stages of catalysts and a pre-silencer, ultimately exiting through quad exhaust tips. The headers are works of art. Pressure-molded at up to 800 bar (around 11,600 psi) to obtain a wall thickness ranging from 0.65–1.00 mm and requiring just a few welds, they weigh approximately 5 lb. each.
Should there be a misfire or faulty combustion within a cylinder, an ion-flow system, similar to that in the M5's V–10, will recognize it. This system senses knock from within a cylinder rather than from the outside. Each power cycle within a cylinder creates a specific pattern of ions, which is continuously monitored. Any noticeable deviation from the pattern will trigger an adjustment in timing. And since readings are internal and not sound-based, they remain highly accurate throughout the rev range. The system on the M5 is an engine-specific satellite unit overseeing all cylinder activity, but the M3's system is modular, integrating the sensors into the sparkplugs as a single unit. (Both Saab and Harley-Davidson have similar systems.)
Certainly the pearl in the oyster, the new-generation BMW V–8 has been extensively researched and utilizes state-of-the-art technology. We're eager to get our hands on one here in the U.S., and we're betting that you feel the same.
M3 engine: Front view.
M3 basic engine with individual throttle bodies.
Cylinderhead with individual throttle bodies and exhaust manifold.
Oilpan with oilpump assembly.
Ignition coil with iconic current measurement system and sparkplug.
Electronic engine management system.
Front view timing drive.
Cylinderhead with camshafts and intake trumpets.
ROADandTRACK.com -- Road Tests, Comparison Tests - M3 V-8: An Inside Look (10/2007)
BMW M
