Car and Driver 2007 Mercedes-Benz GL450 Review
Alx
Member
[image no longer available]
Preview Review: 2007 Mercedes-Benz GL450
A jumbo German storms the field.
BY DAVE VANDERWERP
PHOTOGRAPHY BY GREG JAREM
May 2006
About four years ago, Mercedes started working behind the scenes on a full-size sport-ute, the 2007 GL. That wasn’t a surprising move considering the company had observed that about 25 percent of first-gen M-class owners were ditching their Benzes to buy other manufacturers’ larger luxury SUVs.
Mercedes is no SUV slouch, remember. In 1997, it practically got the mid-size luxury-SUV ball rolling with the M-class. We compared the ML320 with nonluxury brands such as Jeep and Toyota since Acura, BMW, and Lexus had yet to field entries.
And now that the mid-size segment is bursting with high-end choices, other automakers are adding full-size, mid-$50,000 models. The well-established players are Cadillac and Lincoln, which sell roughly 70,000 of these luxury barges — the Escalade and the Navigator — each year. Newer entries include Infiniti’s QX56, around for just over two years, as well as the seven-passenger Audi Q7 that will launch in June, a month after the GL.
Now, don’t confuse the GL with the 26-year-old G-class (Geländewagen), originally designed for the German Army, that starts at more than $80,000. The GL is built alongside the five-passenger M-class and six-passenger R-class at the company’s plant in Tuscaloosa, Alabama. Some 60-to-70 percent of GL production (about 25,000 units) is slated to be sold in the U.S.
[image no longer available]As you may have guessed by now, the GL shares many parts with the R- and M-class SUVs — on the order of 70 to 80 percent. All three have unibody frames, independent suspensions (control arms in front and a four-link setup in back), an excellent seven-speed transmission, and all-wheel drive.
Although the GL is Mercedes’ most spacious product, its 121.1-inch wheelbase roughly splits the difference between those of the M- and R-classes. It’s not the longest or widest of the trio, but the GL’s 72.4-inch roofline is the highest and makes for more headroom than comparable positions in either the M or R.
[image no longer available]Initially, the only engine offered is a 4.7-liter V-8 that is a derivative of the 5.5-liter in the S550 sedan. It’s a new member of the DOHC four-valve-per-cylinder family and makes 335 horsepower and 339 pound-feet of torque — 33 more horsepower and the same amount of torque as the old SOHC 5.0-liter V-8 found in the ML500 and R500. We’ve found both of these new engines to be extremely quiet and smooth, and the free-revving 4.7-liter energetically tugs the 5300-pound GL450 (it will somewhat less energetically tow 7500 pounds, 100 more than an Escalade).
[image no longer available]With a better power-to-weight ratio than both the ML500 and R500, we expect 0-to-60 times in the mid-six-second range for the GL450. Beating the 403-hp Escalade isn’t likely, but acceleration times probably aren’t the deciding factor for buyers in this segment. However, in about a year, Mercedes will add a GL550, with the 382-hp V-8 from the S-class. At this time, there’s no plan for a horsepower-monster AMG model, says Mercedes, but a 45-state diesel option will launch before year’s end.
[image no longer available]The GL rides on standard 18-inch wheels, with 19s and 20s available. It also comes with Mercedes’ height-adjustable Airmatic suspension, which is optional on the M- and R-classes. In this case, the air springs soften the reflexes of the big SUV, riding noticeably smoother than its M- and R-class siblings. Sure, there’s more body roll, but the GL is plenty competent in its segment. For now, it’s too close to call how it matches up to the much-improved Escalade and the Navigator has a lot of catching up to do. The GL’s steering is precise if a touch heavy, but the biggest annoyance is a vague brake-pedal feel. Considerable dead travel causes initial confusion, and even after pads meet rotors, modulation isn’t confident. Every M- and R-class we’ve driven has had this issue.
It’s wise, we think, that the GL isn’t simply a larger copy of the M-class. In fact, the only shared sheetmetal is the front doors. The GL’s styling is more conservative, with a tall, broad profile and much softer shapes than the ML’s creases. Two thick chrome bars across the grille as well as differently shaped head- and taillights further distinguish it from the ML.
[image no longer available]Conversely, the controls are mostly familiar, with two large gauge pods straight ahead, the same four-spoke steering wheel, and a familiar center stack. However, the GL has additional wood accents and a soft, leather-like dash with exposed stitching that improves on the sea-of-gray-plastic look found in some entry-level ML350s. The second row is a 60/40-split bench offering 55 cubic feet of space—plenty of room for six-plus-footers. That bench flips forward (only on the passenger side) to access the two-person third row that has almost nine more inches of legroom than the Escalade’s and more headroom back there than in both American competitors.
There are 11 cubic feet of cargo space available behind the third row, but if you don’t need to seat seven, the second row and the power-operated third row fold flat, exposing 83 cubic feet.
Naturally, there’s no shortage of optional equipment to bump the GL450’s price as much as $25,000 above the likely $55,000 starting point, including a rear entertainment system with two seven-inch screens, a power liftgate, DVD navigation, stereo upgrades, parking assist, active cruise control, and a two-speed transfer case.
In contrast with the somewhat slow-selling, minivan-looking R-class sport-ute, the GL fits into a popular and well-established market segment. Sure, it’s luxurious inside, and the cachet of the three-pointed star is a given. Beyond that, what should really make the opposition wary is the GL450’s roomy interior combined with a competitive price and above-average power.
MERCEDES-BENZ GL450
Vehicle type:
front-engine, 4-wheel-drive, 7-passenger, 5-door wagon
Estimated base price: $55,000
Engine type: DOHC 32-valve V-8, aluminum block and heads, port fuel injection
Displacement: 285 cu in, 4663cc
Power (SAE net): 335 bhp @ 6000 rpm
Torque (SAE net): 339 lb-ft @ 2700 rpm
Transmission: 7-speed automatic with manumatic shifting
Wheelbase: 121.1 in
Length/width/height: 200.3/75.6/72.4 in
Curb weight: 5300 lb
Performance ratings (C/D est):
Zero to 60 mph: 6.5 sec
Standing ¼-mile: 15.1 sec
Top speed (governor limited): 130 mph
Projected fuel economy (C/D est):
EPA city driving: 14 mpg
EPA highway driving: 19 mpg
Mercedes-Benz GL450 Specs
Sayyaaf
Member
promising car ... the pricing would be insane here in the middle east ...
the base price for this is still lower than that of the ML350 here ...
nice car overall .. I wish they gave it the S class interior
MikeJ
Member
I've come to the conclusion that I like the GL (despite not having seen the car myself). If I were in the market for a luxury SUV this would definitely be close to the top of my list, not that I have handy the €122,000 it would take to buy one here. It might be because it appears (and I mean appears) to be more 'honest' than many of its competitors in the sense that it's more 'utility' than 'sport'.
bum-man
Member
I agree. I haven't seen one in the flesh yet (anticipating it) and wasn't so sure when the covers came off, but now I think it really looks the part for the market segment it's targeting. It really looks more like a proper SUV jacked up like that with the Airmatic.
Can't wait to see these puppies with bush gards on and what not.
Edit: They mention a 45 state diesel version, wasn't Bluetech supposed to be legal in all 50 states?
Alx
Member
Original Poster
I didnt like it before, but it is a very competitive market truck and a good base price. This is by far a contendor and a with a mid 6 second 0-60mph, it is pretty fast. Overall im fine with the interior and think it is a very classy luxurious SUV. Im actually impressed with this GL. :usa7uh:
GTA45E
Member
Premium Supporter
AlxAmg said:
This is by far a contendor and a with a mid 6 second 0-60mph, it is pretty fast. :usa7uh:
Wow, I agree! that is pretty damn fast. I believe this GL450 is about as quick as the Caddy Esclade with more than 400hp. I`ll read the article later, thanks Alex.
MoSs
Member
thanx for the article alxamg , what an incredible SUV , i didnt really like it first but now its starting to grow on me . there is like 4-5 in the west covina MB dealler , and im looking forword to stop by "this week" and checkout the car in person .
santpad
New Member
Is there any difference between the 2007 and 2009 models of the GL450? I am looking to buy the GL450, but the new 2009 is priced close to $68k with the options I am looking at.
Santpad
cawimmer430
Member
Santpad
Welcome to GermanCarForum. :t-cheers:
If you're looking for an expert opinion, contact member NevadaJack. He's a former GL550 owner and can give you a lot of helpful information.
