Vath V58K turns Mercedes' SLK55 AMG up to 565hp
Discussion in 'SLK-Class' started by PanterroR, Feb 10, 2009.
  1. PanterroR Well-Known Member
    Tuner cars are often examples of the worst sort of overkill, but occasionally a car will sneak through with less-than-typical appearance modifications and a monstrously re-engineered heart. Such is the case with the Vath V58K, an extreme take on the SLK 55 AMG.
    The Germans at Vath decided that 5.5L and natural aspiration were simply inadequate, and so took displacement up to 5.8L and added a supercharger to boost output from the stock 360hp (269kW) to a thunderous 565hp (421kW) and turning torque up from 377lb-ft (510Nm) to 569lb-ft (770Nm).
    That's enough to push 0-100km/h times down into the 4 second range, just a tick behind the Porsche 911 Turbo Cabriolet. Top speed clocks in at 186mph (300km/h).
    Of course, the V58K isn't without its tuner elements, getting a new aerodynamics kit including a carbon fiber front lip spoiler, and a new stainless steel sport exhaust. Larger 19in wheels wrapped in 235/35 and 265/30 rubber adorn each corner, helping boost grip to match the prodigious power of the Vath roadster.
    Source: Vath V58K turns Mercedes' SLK55 AMG up to 565hp - MotorAuthority - Car news, reviews, spy shots
    • Like Like x 6
  2. Tarek Well-Known Member
    Damn! i want one now:D
  3. LaArtist Premium Member
  4. Merc1 Premium Member
    You could get hurt real bad with such a little car with so much power. GULP.
