SLK55 AMG.... Yee Haa!!!!
Discussion in 'SLK-Class' started by Alx, Sep 27, 2005.
  1. Alx New Member
    Looks real sexy in this pic....
    Car is simply stunning, and as for the power..... Just hold on!!!!!!
    Specifications :
    General
    Manufacturer Mercedes-Benz
    Model SLK 55 AMG
    Powertrain Layout Front Engine / RWD
    Base Price Not Available
    Dimensions
    Length 4087 mm / 160.9 in
    Width 1794 mm / 70.6 in
    Height 1271 mm / 50.0 in
    Wheelbase 2430 mm / 95.7 in
    Weight 1540 kg / 3395 lbs
    Front / Rear Track F 1524 mm / 60.0 in
    R 1549 mm / 61.0 in
    Engine
    Configuration AMG 5.4 Liter Supercharged V8
    Valvetrain SOHC 3 Valves / Cylinder
    Displacement 5439 cc / 331.9 cu in
    Power 268.5 kW / 360.0 bhp at 5750 rpm
    Torque 510.0 Nm / 376.2 ft lbs at 4000 rpm
    Bore 97.0 mm / 3.82 in
    Stroke 92.0 mm / 3.62 in
    Compression Ratio 11.0:1
    Bhp / Liter 66.19 bhp
    Redline Not Available
    Chassis & Body
    Body / Frame Not Available
    Steering Rack & Pinion w/ Power Assist
    Brake Type High-Performance Braking System with Internally Ventilated and Perforated Brake Discs & ABS
    Brake Size Not Available
    Wheels F 45.7 x 19.1 cm / 18.0 x 7.5 in
    R 45.7 x 21.6 cm / 18.0 x 8.5 in
    Tyres F 225/40R-18
    R 245/35R-18
    Transmission
    Gear Type 7G-Tronic 7 Speed Automatic w/ Speedshift
    Final Drive 3.06:1
    1st Gear Ratio 4.38:1
    2nd Gear Ratio 2.86:1
    3rd Gear Ratio 1.92:1
    4th Gear Ratio 1.37:1
    5th Gear Ratio 1.00:1
    6th Gear Ratio 0.82:1
    7th Gear Ratio 0.73:1
    Performance
    Top Speed 250.0 kph / 155.3 mph
    0 - 62 mph 4.9 seconds
    A nice SLK interior too..... superb!
    More pics...
  2. Jono171 New Member
    Yee Haa indeed- That's what I'm saving up for!
    The interior shot you posted is not a 55 though!
    Here's a couple of pics from the SLK55's safety car interior I love the two tone leather up the centre console, the alcantara headliner, carbon fibre trim pieces and the seats. If only they were options on the production version! (sigh)
    Oh and having driven one, I can definately say that 4.9s for 0-100/0-62 is VERY conservative! :icon_cool
  3. Alx New Member
    Beautiful car overall. Trully fast & furious. two tone leather suits the car well.
  4. wltsm Well-Known Member
    I would take the SLK55 over the SL55 any day, a beatiful car!!
  5. Matt New Member
    i thought that engine was N/A. The 5.4 producing 360 horse power wasn't forced induction while the 5.5 in the E class was making 470 bhp.
  6. MoSs Well-Known Member
    no way , the sl 55 is the most beautifull raodster ever....
  7. Jono171 New Member
    I missed that! Good attention to detail Matt! The SLK55 does indeed use the non supercharged version of the M113 v8. As they are slowly phasing out this engine, it is believed that the SLK will have the new 6.3l/510hp v8 in a couple of years! :eusa_danc
  8. Alx New Member
    Yep there is no Kompressor in the SLK55.
    I dont know about choosing the SLK over the SL.... lets not get crazy now.... :t-rot:
  9. Jono171 New Member
    Why not? That would be the sensible choice! It's faster, lighter, cheaper, newer, looks fresher, handles better, and doesn't feel like a boat when you drive it. It's particularly apparent if you drive the SL before the SLK.
    Before I start a row, that's only my point of view! ;)
  10. wltsm Well-Known Member
    Also you can fit an SLR engine in there, as that guy from Dubai did, but no one believed him!
  11. Alx New Member
    Its a matter of preference, for me the SL55 with 500hp, is th way to go. bigger and classier, just a matter of taste i guess.... but lets see what a poll would say?
    Here's the poll --->POLL SLK55 or SL55
