Car & Driver tries to predict the future M3
Discussion in '3 Series' started by Just_me, Feb 8, 2010.
  1. Just_me Well-Known Member
    BMW has gone direct-injection and turbo crazy, an obsession that should manifest under the hood of the next M3 as a hairier version of the turbocharged six BMW uses elsewhere. That twin-turbo 3.0-liter now makes up to 335 hp in new higher-performance versions of the Z4 and 3-series, while a single-turbo six good for 300 horses replaces the twin-turbo in most other applications. This frees the twin-turbo’s output to head for the moon. Having crossed the 400-hp threshold with the V-8 in the current M3, we don’t think BMW will go back.
    Less than 400 hp is possible, however, if the engineers at M decide to go really crazy. We anticipate an overall lightening of the M3 in its next generation, and if that weight-loss plan is particularly successful, we could see a turbo four-cylinder installed in the next M3. The first M3 was powered by a four-cylinder, and if sufficient performance levels can be achieved in a lighter car, there’s a possibility BMW goes back to a four-pot—which would further slash loads of weight from the engine room. And less weight means less power to achieve the same performance—not to mention better handling.
    Fast Forward 2020: Performance Icons of Tomorrow - Feature - Auto Reviews - Car and Driver
  2. aleks_16 Active Member
    next gen M3 + Turbo 4 Zylinder = this Jounalist fail :t-banghea
  3. dr Dunkel Global Moderator
    IF power LESS THAN '400' AND tweight NOT LESS THAN '1450 KGS EC'
    ELSE IF
    power LESS THAN '350' AND weight NOT LESS than '1350 KGS EC'
    THEN
    sales EQUALS '0'
  4. Centurion Contributing Member
    With the existence of the 1-Series coupe the next M3 will unlikely house a four cylinder engine, let alone lose much weight.
    Where's my box of sea salt?
  5. klier Member
    My prediction: V6, 8 speed automatic, AWD and E-diff
  6. ateekt Well-Known Member
    A turbo-charged 6-Cylinder engine with 6-speed manual or 7-speed fancy-auto tranny is my guess! (y)
  7. SCOTT27 Contributing Member
    If I put my "Future thinking " into effect I would suggest something like the Vision Efficient Dynamics. A basic powered combustion engine with performance boosted by electricity?
    For the F32 the groundwork has been laid to the same effect as the X5/X6 M will benefit the M5 and M6 in two different specifications , The M1 will be the foundation for the F32. Although the basis there will be key differences to both just as the X5/X6M and M5 will have it's fair share of individuality.
  8. SKYSONY Well-Known Member
    So the next M3 will have the N54 engine?.
  9. shonguiz Well-Known Member
    No N54 belongs to the Past, the limited Si version are only here to celebrate it.
  10. Merc1 Premium Member
    A small, high-rev, turbo V8 based on the existing engine??
  11. shonguiz Well-Known Member
    No that's too much M.
  12. E38_E30 Active Member
    Come again? You meant I6, right?
  13. martinbo Global Moderator / Editor
    ^ Nope. klier doesn't get his I's and V's mixed up. ;)
    Think of the possibilities. BMW has invested a lot of money in the reverse-flow, vee-located, twin-scroll, twin turbo with cross-flow manifold, V8 engine. [Phew, excuse the mouthful]
    In exactly the same way that BMW lopped two cylinders off the S85 to arrive at the S65 for the E92, couldn't it be highly feasible to do the same with the S63?
    This would achieve packaging benefits, no doubt, with BMW having to worry less about the length of the engine and being able to achieve a better weight distribution too.
  14. Betty Swollocks Well-Known Member
    I'm surprised you didn't focus on the "AWD" comment.
  15. klier Member
    ^ Ofr the auto gearbox in an M3. But then again, you still think the M5 will get that ZF 8 speed right?
    7 speed DCT, here we come. For both the M5 and next M3
    Nah, I meant V6. Because like AWD and an auto gearbox, that will never happen ;)
    There even used to be some talk about BMW going to V6 because the turbo tech should theoretically work better on those engines. It still makes me LOL, thinking about that.
  16. Betty Swollocks Well-Known Member
    OK, I'm struggling to understand what your point is Klier. So you posted the M3 will have 4x4, an auto gearbox, and e diff for what reason?
  17. klier Member
    My point actually was that it won't have either of those thing, just like the next M3 will not have a 4 pot as the article suggested.
  18. dr Dunkel Global Moderator
    AWD, auto, V-configuration and fake diff... now, where have I heard this before...
  19. Betty Swollocks Well-Known Member
    A-ha. I see. It was a sarcastic comment. I'd be careful Klier, otherwise people might start thinking you're serious and you'd be in danger of losing your extremely credible reputation.
  20. Giannis Global Moderator / Editor
    Usually you hear it from MB, but if you spare the V-configuration you can get it from a 335xi, too :D
